DB built on a PC, using on Macs - issues
I have a db that works great on WinXP, my creative team, all running Mac OSX, is having a hard time with some value list pop up lists - it is set up so that in field one, a job number is chosen via a pop up value list, then the 2nd field is populated with the corresponding job name (also a value list). On the PC, no issues, on the Mac, the job number part works fine, but it won't populate the 2nd field, unless the user clicks off of that field, clicks on one some other fielde, then clicks back to the job name field, then it fills the name in. Any one have any thoguhts on this?
Thanks...Kim!!
Hi Kim,
I'm afraid your question got lost in the Friday Night Change over. Hopefully this will bring you some answers.
I use the Popup List on the Mac all of the time, and have not had the problem you have described. In fact, I have always thought that PopUp List worked better on the Mac than in Windows. Maybe something changed in v7
Hopefully, others will chime in with some help.
Thanks!
Is there more info that I can provide that can help figure this out?
Kim
You could provide a sample file that displays this problem.
