Letters and numbers. p1=Unique and 1=Unique
I have a problem in getting validation separate letter+number "p1" and number only "1" as Unique value.
If I define the (number) field as Unique value I get a message that the number is in use if I enter letter +existing numbervalue.
If I define the (text) field as Unique value I have no problem entering Unique values ... but then when I use sort or find...
Need to have numbers as sorting and text when entering. How do I do that.
Or how do I calculate the Unique value upon entering data.
Peter Norling Sweden
Ps. The numbers entered are starting numbers for dragracing and Cars have number (1078) and Bikes have Letters + Numbers (Mc1078)
For number fields, the validation will ignore any non-numeric characters, so 1000 and MC1000 are the same.
In text fields, all characters are evaluated, and 1000 and MC1000 will not be regarded as equal.
So make your field a text field. For sorting, create another calculation field, result number :) GetAsNumber(UniqueField) and sort on that.
Regards,
Peter
Thank's I will try that
Peter Norling
