Unique Code System for Records
Hi, I'm new to this forum and hope I'm posting in the correct place.
I'm in the process of converting our paper based record system where I work to a FileMaker database but have come across a problem when trying to replicate the way we assign unique codes to each client/record. Currently we assign what we refer to as a T No, 235G for example where 235 is the number of records made from the first of Jan that year and the G is the year (G currently =2005). My problems is how do I recreate this system using FileMaker.
What I want to be able to figure out is how I can make FM assign a Letter (G for example) to a year (2005) and then in 2006 make it change the letter to the next letter in the alphanbet (H) automatically and so on. I think I can sort out the numbering system using a serial number field and then I can simply combine the 2 fields together to create the T No.
I'd also want to be able to do a check to see if that T No already existed.
A bit of a tall order I know but if someone could put me in the right direction I would really appreciate it.
Regards
A.Thompson
Why bother to recreate the old numbering scheme at all? The best way to ensure codes are unique is to use an auto-entered serial number, which will NEVER be changed, reset or otherwise modified. This number should have no meaning. It is used by the solution - not by the user.
If you want to DISPLAY - for the user's benefit - a more meaningful code, you can append the yearly letter (although I fail to see why "G" would be more meaningful to a human that plain "2005"). To get the letter, use:
Middle ( "ABCDEFGHIJKLMNOPQRSTUVWXYZ" , Year ( yourdate ) - 1998 , 1 )
"yourdate" can be the record's creation date field, or Status (CurrentDate). If the latter, use a text field with auto-entered calculation.
