maybe Cap'n Kurt will help me once more?
i've got two files: one of people, one of computers.
no problem causing the (as in "one") computer's information to show up in the master file -people is the master.
i have laid out the related fields in my layouts/report.
my problem is: (and i guess there are several "looks", but i just need one good example)... how should i relate and put/insert the related fields in the case of one person having several computers.
(i guess this like a one-to-many, no?) i can't believe that of all these books i've got they only have either only 2 files, which i can do or they have a whole bunch. i really really need rthat intermediary step GIVEN to me.
./rant if anyone wants to send me any files please do: g e t 8 6 a t m a c d o t c o m.
i tried to upload my files to a site but the net was so messed up around here.
thanks very much.
Mac OS X, FMP 5.5
Use a portal based upon your relationship between people and computers. Portals allow you to show the complete (related) list of computers associated with a person.
-bd
so besides the personal information (in the master file) -you say i should a portal in the master for all the computer records to be shown that are associated/related to that person?
how do you suggest to relate the records, since more than one computer record may be related to one person?
Thank you.
(p.s. i'd like to *study* [not do yet] repeating fields too, if that is a way to get more than one ralationship from multiple records to show in the same field of a master file.)
***DO NOT EVEN TRY USING REPEATING FIELDS***
They are a hold over from earlier version of FMP and are NOT used in relational databases!
Here is a simplified version of you system:
People.fp5
PersonID_key
Name
Address
Computer.fp5
ComputerID_key
PersonID_fkey
Type
OS
RAM
Notice that the two files both contain the PersonID field? This is how the files are related. They only need to share that one field to make the whole relational database theory work.
A portal in the People file into the Computer file via the PersonID will show all the computers for that person.
tthank you very much.
i notice that you don't include the computerID as the foreign_key in the person file? am i corect in assuming that that relationship must be made (lest that becomes a key of no use, correct?)?
i'm still at somewhat of a lose as to how a bunch of computer records appear in a portal -i know how a portal works- i'm just not clear on the above question and also on what fields i would put in the portal?
_________________________________________________
i have a name field in the person file -is there a way to tie that in with the personID field, e.g., when ever i add a record the personID field for the new record will automatically be filled in with the next available number?
thanks for following up.
[ September 22, 2001: Message edited by: axis ]
Every record type (Person, Computer, etc) should have a UNIQUE identifier, even if you do not think it will be used right now. ComputerID does not belong in the Person file at all.
There is a one-to-many relationship between Person and Computer, that is one person can have many computers.
For setting up IDs see my article on IDs at http://www.fmforums.com/ubb/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=8&t=000018
