January 13, 200620 yr how can i import a picture from scanner directly in my container fields same as "Insert Picture..." menu item? Edited January 13, 200620 yr by Guest
January 13, 200620 yr this may not help you , but I have found and used in the past a FREE plugin that connects a twain ( not mark) scanner so that with a simple call it brought up the scanners wizard. It work ... ok and did the trick. If you can not find it let me knos directly and I can perhaps find the old app that i used it in and tell you the name. Charles
August 31, 200619 yr I have just look at InsideScan and it scans directly into FM and has many many features, they promise V.2 with even more features, however I'm in terested in the free plugin you mention in the previous post, can you direct me to it? Saludos, Javier
