loop problem
I have a loop script problem in FMP 6 Dev. The Status field indicates whether or not a client has paid (either "paid" or "current"). In order to bill just the "current" records for a particular client, I have the following script to eliminate the"paid" records:
Loop
go to record/request/page
[first]
If (status="paid")
omit record
Go to record/requestpage
[next, exit after last]
End if
End loop
If I have multiple "paid" records and only 1 "current" record, the script works OK. Howver, with musltiple "paid" and multiple "current" records, the script hangs and I have to manually end the loop.
What am I doing wrong?
Do you really have to use a loop? What would be wrong with:
Go to Layout ["LayoutWithClient"]
Go to Field ["ClientName"]
Set field [gClient = Status(currentFieldContents)]
Enter Find Mode[]
Set Field [ClientName = gClient]
Set Field [status = "Current"]
Perform Find []
If Status (CurrentFoundCount) = "0"]
Show Message ["No records for this client are current"]
Show All Records
Go To Layout [original layout]
Else
Go to Layout ["Other layout"]
NOTE: gClient is a global text field or you can use your client key field ID.
Joe:
In your original example, you've put Go To Record [first] inside of your loop, so it keeps going to the first record. It should look like this:
Go To Record/Request[first]
Loop
... your processes ...
Go To Record/Request[next, exit after last]
End Loop
-Stanley
Also note the Omit Record step "Leaves the current record out of the found set and places you on the next record in the table". If you then tell it to Go To Record[next] you have skipped a record!
I've tried Beezer's method and couldn't get it to work. I then placed go to record/request/page [first] before the loop and it also doesn't work. I want to eliminate the "paid" records. How else can I do it without using omit record?
OK, I've figured it out, thanks to Breezer. Instead of using status(currentFieldContents), I copied the clinet ID and pasted it in during Enter Find mode, rather than using Set Field again. Set Field is more elegant than copy and paste, but this works.
