January 18, 200620 yr Hi, I have a graphic in the header section of a report. It shows in FileMaker in preview mode but does not print out. What am I doing wrong?
January 18, 200620 yr In the prview mod you see the first record of found set and if you print current record, may be you have not graphic in this record. May be such?
January 20, 200620 yr Author Thanks, but I've sorted it. It was the graphic format. I was using a GIF. As soon as I changed to a JPG all was ok.
