FileMaker 2026 Released
Activate Security settings will not work
Standard I include or activate accounts and security levels just before I either publish a database or run the final end users tests.
Now I have a 50 GB database in FMP 8 and I tried to activate the already present accounts. (I used standard login using account/password.)
After disabling the standard login nothing changes, as if the security isnt really active.
When I create a clone of the database it all seems to work fine.
It got me by surprise as I didnt expect this behavior.
Any advice how to get this (*&(I*& security and accounts active without having to rebuild starting from the clone?
The 7 million records will take more then a month to be imported into FMP clone. Seems like a terrible waste of time.
TIA
Rob
Welcome Rob,
Can you be a little more specific about what's actually working or not working. I don't know what "standard login" or "nothing changes" is really saying.
Also, how many files and how many accounts are we talking about here?
Sorry if that was not clear: standard log in is with an account preset, e.g. Admin/password.
Disabling that should enfource you to use an account name and the appropriate password. That now is not working in the database, yet is works immediately when I save the database as a clone (and fill it with some data)
Hope this clearifies my question.
Regards,
Rob
Not much.
Do you mean you're disabling the automatic login option in File Options, and it's then not giving a Login dialog when the file is opened?
Perhaps you have an OS X keychain set for it. Check Applications/Utilities/Keychain Access.
That is what is happening. But the password differs from the standard keychain password. And since it does work accordingly, starting up with an login window when I create a clone from the same database, it doesnt make much sense to me. I merely want to have any user being forced to login using their account and password and hence their permissions on the file.
The keychain remembers the password for that particular file on that computer. If you move the file to another machine, the user should be presented with a Login dialog (which they may or may not set their own keychain on.) If you wish to get the login dialog back on your computer, delete the keychain entry for that file.
I stand corrected you were right
thank you for this tip, otherwise I sure would have wasted lots of time
No problem, Rob.
This feature of keychains is meant to be a useful thing, and I'm sure in environments where everybody has their own computer, it is. In my environment, I have many users that share computers, so this "feature" is a big security risk. And yes, it's a pain to work around.
But it's useful to know about it (and know how to deal with it,) even if everyone has their own computer, as eventually employee turnover will result in a situation where the new employee gets logged into the old employee's account unexpectedly. :shocked:
thanks for the info again.
The funny thing is, and thats what pulled my leg is that the same logon happened when I opened another account (other user and password) and opening the fmp database.
It made me blind for the keychain. Thanks for the eyeopener
Rob
