February 25, 200620 yr I'm using this calc for my Phone Number custom function. I got this either off this site or CC support forum. Everytime I enter a number I get an error message. I then re-input the same number and it works fine. Case (IsEmpty ( Phone Number );" "; Length(Phone Number) = 7;Left(Phone Number;3) & "-" & Right(Phone Number;4); (Length(Phone Number) = 10); "(" & Left(Phone Number;3) & ") " & Middle(Phone Number; 4; 3) & "-" & Right(Phone Number;4); "Wrong number format") Can anyone tell me what's wrong? Thanks, Al Edited February 25, 200620 yr by Guest
February 25, 200620 yr I just tested this as a calculation and it works (it should work then as a CF) is your field TEXT result, and is it big enough to show the results. (i.e. if you see a ? in there, then it needs to be widen. HTH Lee
February 26, 200620 yr I take it you are putting the result back in the Phone Number field? If so, have a look to make sure your field is really empty when you start entering data. Why do you set it to a space when it is empty?
February 26, 200620 yr What exactly is the error message? And i think it may or may not have to do with your space when its empty like Oldfogey suggested. ~Genx
February 26, 200620 yr Author As I stated I copied this from either this forum or CC forum. I deleted the space from the calc and it seems to work fine now. Thanks for all your input. Edited February 26, 200620 yr by Guest
May 15, 200619 yr When I copy and paste this calculation and try to enter data I get a dialog box telling me the field is not modifiable. What am I doing wrong? FM 8 advanced on Mac 10.4.6
May 15, 200619 yr Author Did you set it up as a Custom Function or simply a calculation within a field? Is the field set as text? Can you post a copy/clone of your file or show us pictures of your field set up?
May 15, 200619 yr Your field should be a text field (or anything thats not a calc or summary) with auto enter calculation checked (with your custom function calc in here) and do not replace contents unchecked.
