Calulation or Script Help
I am new to filemaker and have a most likely easy problem to solve. Although I cannot solve it.
I have a check box field. If the checkbox is selected I want a differnt text field in the layout to display a message. If the box is not checked I do not want a display.
I understand that the display would be default text insert in the text field.
ie. I have a slip that is being used for sick time and other events. When the sick time check box is checked on the form I want a text box on the footer of the form to have SICK TIME entered in it.
Should this be a script or a calculation with a text result?
How would I do it.
Ed
Here's a file that may help. I'm sure there are much better answers from the more experienced folks, but it works.
Al
Sick_Time.zip
