March 2, 200620 yr Hi all, Hope someone might be able to make a suggestion. I have 2 databases. One is for contacts the other for jobs. Each contact has a unique ID and each job has a serial number. I would like to be able to paste the contact ID into a box on a newly created job on the Jobs database so that the companies name, address, telephone and fax info from the Contacts database moves across automatically to the respective company name, address, telephone and fax empty fields on the jobs database. I can't figure out the relationship between the 2 database and the identical fields in both? Although each job has a unique serial number, a contact can have different jobs on the go. Help! Probably a newbie question I'm sure! Edited March 2, 200620 yr by Guest
March 2, 200620 yr Hi all, Hope someone might be able to make a suggestion. I have 2 databases. One is for contacts the other for jobs. Each contact has a unique ID and each job has a serial number. I would like to be able to paste the contact ID into a box on a newly created job on the Jobs database so that the companies name, address, telephone and fax info from the Contacts database moves across automatically to the respective company name, address, telephone and fax empty fields on the jobs database. Probably a newbie question I'm sure! I just answered this on another list. I have reproduced my answer with a few changes here. Hope this helps you Dave McQueen ......................................... pseudo script here: Two files - Parent and Child ScriptParent1 Freeze Screen Copy Prime Parent ID Call Subscript External in Child File/Table (ChildCreateRecord) ChildCreateRecord GoTo Layout (With correct fields) NewRecordRequest Paste ParentID into Parent_Ident_Field Refresh Screen in Parent File/Table Have the other fields in the child file/table lookup fields to pull in data from the parent file/table You can do this with variations setting a related global field in a prefs file/table and then setting the parent ID field in the Child File from this same global through another relationship - which gets you away from copy and paste operations. In a network scenario it is important to go right into the child file to create the record and keep that record tied up until the applicable keys are set. HTH Dave McQueen
March 2, 200620 yr Author Hi David, Thanks for the reply. Do I need to establish a relationship first between the two database? I'm getting as far as "call subscript External in Child File/Table...." ?
March 2, 200620 yr Perhaps you should clarify a few things here: When you say "2 databases", do you mean 2 tables in the same file, or do you actually have 2 separate files (and if so, why)? You indicated that one contact can have many jobs. Can a job have more than one contact?
