Begging Help with Relationships for Report
Scenario:
One employee can have many grants.
One employee can have many gifts
One employee can have many subcontracts.
I have 4 tables: Employees, Grants, Gifts, Subcontracts. (Please see attachment)
Each Grant, Gift and Subcontract have a unique account #.
-All Grants start with an account# starting in 1.
-All Gifts start with an account# starting in 2.
-All Subcontrats start with an account# starting in 3.
Problem and Question:
1. If I change the employees id, first name, or last name in the employee table, the grants, gifts, and subcontract table does not update the new employees name.
How can I get it to do this throughout the grants, gifts, and subcontract tables?
2. I have never created a report that pulls data from [color:red]4 tables. Pretty please help me to create [color:red]ONE grand report that is sorted by an employees last name. Below the last name of each employee, it will display all the account #’s for grants, gift, and subcontracts that employee has. Then gives a subtotal for that employee. I will need a grand total to show the grand total $ for all employees.
Help???
Example:
10 John Doe
Account #101 Grant from Fed Govt. 50,000
Account #201 Gift from Ford Corp 10,000
Account #202 Gift from McDonls 15,000
Account #301 Subcontrat Mrs. Green 5,000
Subtotal for John Doe $80,000
Grant_Gift_Subcon_DB.zip
Hi, Maria!
I edited your attachment for first question.
About second i will think.
One of way for report is importing all of Grants, Gifts and Subcontracts records to one table and in this table make report. If you will have problem on it attach your file with little more records i will try to create report.
Thank you so much for your help.
I have added more records per your request. (please see attachment). I also created a table and named it "Combination" which will hold all the grants, gift, and subcontract data. I am not sure if this is correct.
Would you be able to check it out and make any necessary changes to make the report successful.
If i make changes to example: grant table, then it should update the report with the new changes.
Thank you again for your time
Grant_Gift_Subcon_revised.zip
Thank you a million.
Hello aaa,
Were you able to check out the new zip file with new records for the report.
