PDF in Kiosk Mode Problem
HI,
I have created a small db, one of the buttons is attached to the "Save Record As PDF" script.
everything works great until I compile it as a runtime.
Once opened from the runtime my button which I attaced to the "Save Record As PDF" script will not function. It just blinks when it is clicked.
Any ideas on what I may have done wrong?
Also the PDF option on the menu bar is also greyed out, but the Excel option is active?
Thanks for your time,
Jim
It's not you...PDF's are disabled in kiosks and runtimes. The workarounds are a plugin, or utilities such as Bullzip (free).
Steve
Thank you for your reply, I assumed that I was going to need an outside program to accomplish this.
Thanks again,
Jim
I use the Schubec plugin. It's not cheap, but it works well, and can be installed quietly if need be.
Steve
