need to extract an address into parts
Hello
I have a file that has addresses in it like the one below
Glenwood Cemetery
Address: Glenwood Ave, Oneida, NY 13421
Phone: (315) 363-1420
I would like to automate putting the first line into a field called business
I would like to break up the second line to the fields "address" and " city" and "state" and "zip" fields accordingly
and I would like to remove the word phone and put the third line into the field ' phone"
Thanks very much for your help
The word address, is always there as well
You might try this (see attached). Import into the textField and then the auto-enter calcs will split it into those fields. Once imported, the data will remain set. You can then modify the new fields if need be. The textField should be left as an audit trail of your import.
Addresses.zip
