Columnar list/report problem
I hope everyone is having a good week.
I have layout designed to be a Columnar Report. It works, as long as I do not perform a find before I view it. After the find is performed, the grouping based on a field no longer works. This is true for all layouts using the table used in the find. "Show all Records" has no effect on the problem. I have to restore a backup of the file to correct the problem.
Help?
Was this file migrated from an earlier version of FileMaker (i.e. 6, 5, 4 etc.)
Is this a Scripted Find? If so, have checked to see if it is broken.
