Help with Applescript Dialogs
code:
display dialog "Please enter your password..." default answer "" default button "OK" giving up after 5
copy (dialog reply button returned) to v_button
I run the dialog and get an "Execution Error" message. It says "Cannot make some data into the expected type".
I am sure that I have some formatting errors, but I do not know what. Any suggestions?
Kurt:
What are you trying to do here?
display dialog "Enter PW" default answer "" buttons {"OK"} default button 1
set v_button to button returned of result as string
display dialog v_button
will return and display the name of the button clicked
whereas
set pw_text to text returned of result as string
will capture what's entered in the text box
Old Advance Man
Basically I am trying to do 2 things. One is to make sure that the user pressed the "OK" button and if so capture the text that they entered into the "Password" field.
I am sure that my process is correct, I am just having touble with the syntax. I'll try your suggested format and see what the results are.
here a little solution.
set PWT to ""
set PW to {text returned:PWT, button returned:"", gave up:false}
repeat until (gave up of PW is true) or (text returned of PW is not PWT)
set PW to (display dialog "Enter PW" default answer "" buttons {"OK"} default button 1 giving up after 5)
end repeat
if gave up of PW is false then
-- something using (text returned of PW)
else
-- other thing
end if
