Big problem, help!
Ok ive got myself in a right muddle!
I used the developer tool to set kiosk view for non admin accounts. I then carried on editing the database (for several days). I now need to remove that kiosk mode for non admin accounts!
I tried running the file through the developer tool again with the kiosk mode unchecked, but it is still throwing me into kiosk mode.
I really need to remove this setting, because i have done so much work i really really dont want to go back and do everything again :
Can you help
Ben
I think that you are stuck with kiosk mode on any file that has it invoked.
Phil
bugger :
  • 2 weeks later...
"I think that you are stuck with kiosk mode on any file that has it invoked. "
Wrong.
Any full access username/password will give you - well - full access.
Of course Bruce is correct but since modles had indicated that he had set kiosk mode for non-admin accounts I presumed he realised that admin accounts were still ok.
What I meant was that for all non-admin accounts he is stuck with kiosk mode. I know of no way of 'undoing' this mode
Phil
