Problem with Replace field content
Anyone has problem with Replace Field Content Script step in FM Advance 8.5 on Mac.
A very simple script, crashing every time when it gets to this step. There is no sharing just stright step ;)
Have you navigated to a layout that contains the field that you want to replace and then also gone to the field before you issue the replace step?
Phil
Thank you for your response.
I found out that there was a problem with a field definition after running the recovery step.
