Help with Scrip to be able to print containers under my tabs!
I need Help with script. Im trying to print all my containers under different tabs from the same record without having to go one tab at a time.
Is there any way to print all at the same time?
Hi
yes, you need to buid a new layout with all your containers and print that ! ;)
IF i do that then what can i do to get rid of the blank containers that don't have any jpegs?
Slide
