Webcmp problems on G4 Cubes
I don't know if it's hard- or software related but it's impossible
to get FM 5.0v3 and Companion v6 to share the files over the web without crashing and returning error -2.
This problem does only occur on our brand new G4-450 Cubes!
3 of them with the same problem.
I have tried all companion versions. I also installed FM 5.5 but the problem persists.
Since it works on every other machine it must be a Cube related problem.
Is it something with MacOS 9.1?
Grateful for any help or ideas.
regards
Hannes
I'm not a big fan of OS 9.1. I'd go back to 9.0.4 and turn off as many extensions as you can. One of my customers runs four G4/450 Cubes with FM Server 5.0, RAMBunctious (RAM Disk), Kick-off (crash recovery hardware), and fans built into the server shelf. Stability has been excellent, better after we disabled every extension we could get away with. We've not used Cubes to web host, but you might give this a try.
-bd
