January 3, 200719 yr Hello! i have one field called "studied" that has a value list called "subjects", i have another field called "completed" with a "yes/no" value list. I want that when i click on "yes" on the "completed" field, all the checkbox in the "studied" field to be checked, and if i click "no" nothing to happen. How can i do that?! thanks!
January 3, 200719 yr Here's an example file that demonstrates how to do it with an auto-enter calculation. Make sure you uncheck the option to "do not replace existing value" when setting up the auto-enter calculation. CHECKALL.FP7.zip
