Help Printing (or not printing hehe)
Hi I am stuck here.
I have a few nice layouts for my database... in the header area I created buttons (New, Delete, Search, Show all) and tabs (to switch between layouts) to make it easy for the people in my office to use. However, the buttons seem to print when I go to print a record. Is there anyway to have my buttons and tabs on screen and then NOT have them show up when printing? I imagine there must be a way to NOT have the info in the header to print? I hope its just a matter of me not being able to find it.
Jared
1. Go to Layout Mode
2. Select the objects that you dont want to print
3. In the Menu Bar, Go to Format --> Set Sliding/Printing.
4. Check 'Do Not Print the Selected Objects'.
Excellent! Thank you so much!
