FileMaker 2026 Released
self join relationship problem
I am creating a database which will accept new orders and look to older, shipped orders and last names to see if the new order is from a prior customer. This will allow me to assign the prior customer ID number rather than a new one.
The relationship is order_status="shipped" AND lastname = lastname.
Unfortunately, it doesn't work. Only the lastname match seems to work, not the order_status=shipped. Any thoughts?
I am using FMP 8.5 on a Mac.
InternetVenturesDownloadExp.fp7.zip
You just have your fields reversed in the relationship.
Switch Status_is_Shipped and OrderStatus around.
Since the OrderStatus is the variable field it needs to be the one that the portal is dependent on. I would also suggest that you use a global calc field instead of an auto-entered value. Just make the value of the calc "Shipped".
Excellent!
Thank you!
