Portal Scrolling Problem
As I click to scroll down in the Portal, the records at the bottom apprear to duplicate again and again as I scroll down until the scroll bar reaches the bottom, but they are not really there in the Table. If I go back to the top and just pull the scroll bar to the bottom they appear fine. Why is the Portal scrolling this way. It dosesn't matter if it is locally on the PC, or from Server Advanced
Mark
I've seen this happen on several occasions, and believe it was a bug that was fixed by an update. I've also seen this when the top or bottom of the field in a portal is just at or beyond the bounds of the portal.
I don't have anything too close to the edges of the portal and Upgraded to 8.5 Advanced.v2 and still have the problem
Any other suggestions
