problem installing FMSA 9 JNLP 1.5
I tried to install FMSA 9 developer edition and the console wouldn't start because it said that only JNLP 1.0 was supported and my computer has 1.5
anyone else have this problem and/or know how to rectify or revert to 1.0 on os X 10.4 ?
"Unsupported JNLP version in launch file: 1.5. Only version 1.0 is supported with this version. Please contact the application vendor to report this problem."
To fix this:
Select the downloaded admin_console_webstart.jnlp file (JNLP) and do a Get Info ( Command+ I)
You can locate the admin_console_webstart.jnlp file where your browser saves downloaded files
Change the “Open with “ which is set by default to “Java Web Start (11.5.0)” to “Java Cache Viewer 11.5.0”
Click on the “Change All” button and click OK on it’s dialog to apply to all JNLP files
Now you should be able to double click and launch application from JNLP with out an error
