Rowspan problem
Hi!
I'v got a problem with the "rowspan" HTML-tag, when showing the searchresult from a Find operation.
The page generated is a schedule over the week, containing reservartions.
(Example here )
Every row with the hour on the left, is a found record, and the reservations for each day is portals to a record containing the specific objekt, time and client etc.
I want to expand each reservation to cover the hours in the specific reservation - the reservations are supposed to cover the time in the schedule!
Is that possible?
How can I use the Rowspan-tag to span over the next found record, without getting the wrong HTML-code when the pages are generated?
Or is there another way to solve this problem?
/M
[ February 06, 2002, 07:05 AM: Message edited by: Spacemanspiff ]
How about creating a calculation field that calculates the length of the reservation in hours, and insert that into your ROWSPAN tag?
Sorry I didn't explain the problem good enough.
Here is the code that generates the schedule (a little bit modified, but this is the basic part):
code:
<TABLE>
[FMP-Record]
<TR bgcolor="#CCCCCC" align="left" valign="top">
<TD width="50">[FMP-Field: TimeOfDay].00</TD>
<TD width="100">
[FMP-Portal: ReservationsMon]
[FMP-Field: ReservationsMon::Time]
[/FMP-Portal]
</TD>
<TD width="100">
[FMP-Portal: ReservationsTue]
[FMP-Field: ReservationsTue::Time]
[/FMP-Portal]
</TD>
<TD width="100">
[FMP-Portal: ReservationsWen]
[FMP-Field: ReservationsWen::Time]&nbsp;
[/FMP-Portal]
</TD>
<TD width="100">
[FMP-Portal: ReservationsThu]
[FMP-Field: ReservationsThu::Time]&nbsp;
[/FMP-Portal]
</TD>
<TD width="100">
[FMP-Portal: ReservationsFri]
[FMP-Field: ReservationsFri::Time]
[/FMP-Portal]
</TD>
<TD width="100">
[FMP-Portal: ReservationsSat]
[FMP-Field: ReservationsSat::Time]
[/FMP-Portal]
</TD>
<TD width="100">
[FMP-Portal: ReservationsSun]
[FMP-Field: ReservationsSun::Time]
[/FMP-Portal]
</TD>
</TR>
[/FMP-Record]
</TABLE>
So. The problem is that I cant make the portals that contain values to "stretch" over to the next row since that row is generated by WebCompanion (note the FMP-Record tag!).
If this was an ordinary webpage, with static content, it wouldn't be a problem...
