X2Max Plug-in help...
I am trying to produce the GRID and labels to my DAY VIEW with the X2Max. The code is below:
I need to have times on left and right and Rooms on the top and bottom. How do I get my first minor tick to be NULL. As you can see in my CODE, they (the minor and major times) are stacked on TOP of each other. Are there any other way to optimize this code that you see? My thought is once I get the PRIMARY GRID generated, I can then add some variables to change it. For example DayStartTime, DayEndTime, TimeUnit (5,10,15,20,30,60 minute blocks). Would be better to divide the grid into categories? Like one chart drawing per column?
Again I appreciate any help you can offer ;-)
Don
OpenDrawing(850;560)
OpenChart(50;30;750;500;on)
ChartData(
0:00 0:00) // NULL
GanttChart(label+horizontal;0)
// set up axes
Scaling(x;linear;0;6;6)
Scaling(y;linear;8:30;13:30;hour;minute10)
ScalingOptions(y;on) // y-scaling from top to bottom
AxisMajorTicks(y;0;1;black;;out)
AxisMinorTicks(y;0;1;black;;out)
AxisMajorTickLabelTexts(y;"|h:mm|")
AxisMajorTickLabelStyle(all;"Verdana";10;bold)
AxisMinorTickLabelStyle(all;"Verdana";10)
AxisMinorTickLabelTexts(y;"|:mm|")
AxisOptions(y;;on)
AxisMajorTicks(x;1) // hide x-axis tick marks
AxisMajorTickLabelOptions(x;;;2) // move labels down by 2-pixels
AxisOptions(x;;on) // move x-axis to the top
AxisMajorTickLabelOptions(x;;3;-2)
AxisMajorTickLabelTexts(x;"Room A";"Room B";"Room C";"Room D";
"Room E";"Room F";"Room G")
// set up grid
GridFrame()
MajorGridLineColors(x;y;darkGray)
MinorGridLineColors(all;all;lightGray)
MajorGridStripeColors(y;x;;;;;;255 235 235;255 235 235)
MajorGridStripePatterns(y;x;transparent)
CloseChart()
ChartData(
0:00 0:00) // NULL
// set up axes
AxisMajorTickLabelOptions(x;;3;2)
// set up grid
GridFrame()
CloseChart()
CloseDrawing()
