auto resize body to print
Hi, is there anyway to auto resize the body part of the layout before printing. I have a layout wich displays email, some are short some are long, i display the email in a browser object so when the email is small everything fits in but when its long i only get the top part of the email. Is there anyway to automatically resize the body part or just the browser object to show the complete email.
thanks
mfrapp
You can not change the size of a body part.
You can however have your fields slide and shrink to eliminate white space. Look at Removing blank spaces in printouts in the Online Help.
HTH
