How do I enter layout mode using a script?
I have users who only need to be able to tinker with one particular layout in the FileMaker file. It is their report, and sometimes they will want less fields displaying than other times. I am trying to figure out how to keep the database secure while allowing this. I made a layout and gave this user group the privileges to modify the layout, but not change any records from this layout.
At the moment, they can only see the layout in browse mode and not layout mode. I'm just struggling with how to give them a button to click from browse mode over to layout mode...
as i know you can not switch to layout mode within a script. may be custom menu can help to do this. For the layouts that user may change the layout install different menu set, that allows to switch layout mode. So user can enter layout mode from new menu set.
F. Osman Cabi
