August 29, 200817 yr When importing images from a folder - reference only: If you have a folder with an image called "image1.ai" (or whatever) in it and a sub folder with a different image called image1.ai, Filemaker only finds the image that is higher up the path even though the imported file path is correct. Is there a way of overcoming that so the image that filemaker displays is the image that is further down the directory?
August 29, 200817 yr Well I tested this using 8.5 and 9 on 10.4.11 and it works fine. Did you make sure you selected to include subfolders?
