Assigning Serial Numbers to Products.
Greetings,
I have added a new table to my database called "Serial Numbers" - I know, original. In the table "Serial Numbers" there are 7 fields.
*SN_Serial Number Prefex
*SN_Serial Number
*SN_Category_1
*SN_Category_2
*Category Full Name
*SN_Serial Number Complete
*SN_Status
SN_Serial Number Prefex:
Just a field that has the first part of the Serial number stored, for example Adult Games is AG. Books & Mags is BM.
SN_Serial Number:
Just a field that contains the Second part of the Serial number, this is basically 500 records that have a increase of one. For example 0001 - 0500.
SN_Category_1:
Has a field that contains a drop down box that brings up a list of the Categories.
SN_Category_2:
Has a field that contains a drop down box that brings up a list of the Sub Categories that are affiliated with the Category field.
Category Full Name:
Contains the Category and Subcategory names together in the one field with a _ in the middle of the two. (this is set for reationship use only).
SN_Serial Number Complete:
Joins the first and second part of the Serial number together, for example Adult games becomes;
AG0001
AG0002
AG0003
SN_Status:
This has two possible enteries, Assigned and Unassigned. This is a Calaculation field. The code is below that should decide between the two.
Case(SN_Serial Number Complete = Product Catalog::v_products_model;"Assigned";"Unassigned")
[color:red]The Problem:
The first record is working well, it returns "Assigned" for the Serial Number AG0001. However the rest of the 500 of them all return "Unassigned"
I don't know why it isnt working on the first record but not on the rest of them.
Anyone have any ideas why ?
Assuming your Serial Numbers SN_Serial Number Complete is related to Product Catalog by v_products_model, that calc should work, although I'd probably write it:
Case( not IsEmpty( Product Catalog::v_products_model) ;"Assigned";"Unassigned")
Or I'd make SN_Status a number field, rename it SN_Assigned, format it as a checkbox with a value list of "1" and calculate it like this:
not IsEmpty( Product Catalog::v_products_model )
But I digress. It seems to me what's relevant here is not how you constructed your SN_Serial Number Complete field, but how you constructed your relationship to Product Catalog. You haven't told us anything about that.
Also, does your SN_Status calc return a text result?
Greetings;
I was playing with the relationships last night and managed to get it working a bit better, now instead of just the first one, it is doing others, however it still isnt 100 %. infact more like 50 %.
I am starting to wonder if there are too many records for it to look up and it is getting it's self confused or something.
Above is a picture of the relationships.
Okey, this is weird, it works when there is data in the Subcategory field, infact it works like a charm, but it won't work 100 % when there is only data in the field Category_1 and nothing in Category_2.
