Activate a container field using a script step in IWP
I have a database with a container field in each record that has a reference to a pdf report. I created a layout that will list all the reports available to the user. I am trying to write a script for each button that will go to the appropriate record in the database and activate the file in the container field.
I have tried the set field to the container field with the Select/perform option and that did not work.
If I show the layout in list form, I can click on the container field and the file will open. I am trying to automate that process in an IWP script.
Any suggestions.....
Perhaps you should consider this:
http://www.360works.com/supercontainer/
  • 4 weeks later...
I am trying to get the same thing done, if you figure it out pls post here, thank you
Manuel
