Help required with Let function
I am trying to re-format a timestamp in order to put it into a larger calculation (to compile a file path using variables) and FP is prompting me that there are too many parameters. Have I missed something or am I not able to use the Case function within the Let function? Here is my calculation;
Let (
$year = GetAsText ( Year ( Get ( CurrentTimeStamp ) ) );
$month = Case(
Length (Month ( Get ( CurrentTimeStamp )) = 1;
"0" & GetAsText (Month ( Get ( CurrentTimeStamp )));
GetAsText (Month ( Get ( CurrentTimeStamp ) ))
$day = Case(
Length (Day ( Get ( CurrentTimeStamp ) )) = 1;
"0" & GetAsText (Day ( Get ( CurrentTimeStamp ) ));
$hour = Case(
Length (Hour ( Get ( CurrentTimeStamp ))) = 1;
"0" & GetAsText (Hour ( Get ( CurrentTimeStamp ) ));
$minute = Case(
Length (Minute ( Get ( CurrentTimeStamp ))) = 1;
"0" & GetAsText (Minute ( Get ( CurrentTimeStamp ) ));
$seconds =
Case(
Length (Seconds ( Get ( CurrentTimeStamp ))) = 1;
"0" & GetAsText (Seconds ( Get ( CurrentTimeStamp ) ));
$year & $month & $day & $hour & $minute & $seconds
:) In your Let statement the 5th line [the one that begins "Length(Month......."] you have three left parentheses and two right parentheses. I don't know if this is all that might be wrong but try it and see. You need to add a right parenthesis [color:red]")" at the end of the line right before the equals sign. (like below)
Length(Month(Get(Current TimeStamp))[color:red])=1
The calculation is missing also 3 ";" ...
Each variable must be separated from the next one with a ";"
BTW: this is simpler:
Let([
t = Get ( CurrentTimeStamp ) ;
$year = Year ( t ) ;
$month = Right ( "00" & Month ( t ) ; 2 ) ;
$day = Right ( "00" & Day ( t ) ; 2 ) ;
$hour = Right ( "00" & Hour ( t ) ; 2 ) ;
$minute = Right ( "00" & Minute ( t ) ; 2 ) ;
$seconds = Right ( "00" & Seconds ( t ) ; 2 )
