startup script problem
I use a script to create a backup file for test purposes. It inserts the words Test Copy at the beginning of the file name for easy identification. For example: Test Copy Clients.fp7.
A startup script runs when the file opens. It tests the FileName and sets a global for display purposes:
Set Variable[$filename; Value:Get (FileName)]
If [LeftWords($filename;2)=”Test Copy”]
SetField[issues::gTestCopyAlert; “TEST COPY”]
Else
SetField[issues::gTestCopyAlert;””]
End if
If the words Test Copy appear in FileName, gTestCopyAlert displays the words TEST COPY on the layout.
The problem is that when I create the test file and open it for the first time gTestCopyAlert is not being set. It remains empty. I must close the file and re-open it for gTestCopyAlert is set properly. It then displays properly on subsequent opens. In other words, I have to run the startup script twice before it works
Just a wild guess here but is it possible that the storage of the global field isn't actually set to global?
I just built a small file and tried your script and it works as expected. My guess is that you have done what I often do myself and just made a simple mistake. Double check the simple stuff and I bet you find the problem there.
Just a clarification. I notice if I run the startup script a second time, the script works!!! :B :
