problem with webviewer reload
I'm having trouble with updating the webviewer. The only way it updates is if I go to layout mode and back to Browse mode. I have tried Resetting, Reloading, I am setting the base url in the beginning. Doing everything that I am supposed to. Any ideas?
thanks in advance.
-Kevin
Is this a problem that's only happening with SuperContainer, or is it a problem that you're having with the Web Viewer in general? If it's specific to SuperContainer, what version are you running?
thanks for the reply Jesse.
after doing alot of testing, I think I have it figured out. My webviewer address has a calculation in it, and Filemaker was not recalculating until I commit records, or change the field that the calculation is based on. (sorry, hard to explain by a novice). In any case, I have it working now by just adding a step that reupdates the contingent field.
Thanks!
