need help w/script
need help with one script … I am working with a file/database w/3000+ clients … I need to create a button w/password (I know how to create this) for the following script … which i need help setting up ...
find all records / show all records
export the following : customer name, address, city, state, zip (as tab, since excel export just doesn't work in FM 8.5 and windows xp)
create folder on desktop
export
go back to original layout …
I already know how to do all of this without the script, but our database is set up with security, so I need the script so that certain people can perform this duty without logging in as the administrator with access to all menus …
the script seems simple enough, but I cannot get it to work even referring to similar scripts already within the file … any information anyone could provide would be helpful … thanks in advance …
Use the "Run script with full access privileges" checkbox.
thank you for that information ... seems that will address the button w/password issue ... but actually it's the script itself that i need help with ... i know this may seem really basic, but that is what i am looking for ...
You've basically written the script already. The one problem is Create Folder, there is no such option in FileMaker. If you really need that, it can be done with a FileMaker plugin.
However, if you can get by without creating a folder, instead just exporting to a known location (e.g. the desktop), you can do it this way:
Set Variable( $path ; "filewin:" & Get(DesktopPath) )
Export Records ( $path )
Does that help?
thank you ... i was aware of sending this tab to the desktop, but couldn't separate the other "find info" from my reference script ... will try what you have given me ...
If you really need/want to create a folder on the desktop, this can be done without a plug-in.(Windows only) You can use the "Send Event" script step to send a command to the "run" line of windows (works similar to the command line). I do not remember the exact command to create a folder (I think there was an example posted on the forums at one time) but it can be done, and is fairly easy to do.
Go here for examples:
http://www.computerhope.com/mdhlp.htm
MKDIR [drive:]path
MD [drive:]path
Thanks for pointing that out. FWIW, you could also create a folder in a similar way on a Mac using AppleScript.
