January 9, 200917 yr Newbies Hi all I am having a problem having the max function work with a sql table in filemaker. I have the Sql table in filemaker and i created an extra field in filemaker named it Constant and has always Value 1, i created a new table with 2 fields , Constant , MaxID. I create a relationship to the two tables through constant and created the calculation Max ( ID ) in the MaxID field, but this never return me the maximum id number from the sql field. Sql Table___________________Filemaker Table Constant(FM Field)_---------_Constant ID__________________________MaxID (Max Function) If anyone got any solution thank you Edited January 9, 200917 yr by Guest
January 10, 200917 yr I don't have experience with SQL, but if this were two FM tables, you just relate them thru Constant=Constant or using a cartesian (x) join. Now table1 sees all the recs in table2. The calc in table1 is: max(table1::table2:numfield).
January 11, 200917 yr Author Newbies Thank you for the reply I have already done a relation through constant but the problem is the ID is a serial number that is created in both sql and filemaker, when a new ID is created on the sql the Max Value in filemaker doesn't refresh. I have also noticed that when there are many sql records filemaker does a lot of time to do the refresh. I am thinking maybe creating the Max value on the sql side i hope maybe that way it works.
January 11, 200917 yr The goal is to get the maximum ID in the SQL table? Why? Are you aware that if a relationship is sorted by ID desc, the first related record would contain the maxID, given an auto-enter serial. Or, use the Last() function on a non-sorted relationship. What are you doing with the MaxID once you have it?
