February 3, 200917 yr hi, we have a problem with a summary field in that it recalculates the total in a related file, the field is not displayed in this related file, and none of the fields used in the summary/calculation (for Points_s) are being updated... the user is then forced to wait while the Points_s field is recalculated. this is problematic when the file in which these fields is stored contains ~50,000 records. in general the Points_s field is used in reporting to determine how many points a person has accumulated based on various flags. details of the field are as follows: -- Points_s = Summary field, Total of Points_c -- -- Points_c = Calculation field, Unstored ( Level * 1.5 ) * ( Tenure / 52 ) + Case ( ISW = "Y" and Status = "On"; 4; ISW = "Y" and Status = "Off"; 1; 0 ) -- -- Level = Number field, Indexed -- -- Tenure = Calculation field, Unstored ( End Date - Start Date ) / 7 -- -- End Date = Date field, Indexed -- -- Start Date = Date field, Unidexed -- -- ISW = Calculation field, Unstored If ( PatternCount ( Ready; "Independent" ) > 0 or PatternCount ( Ready; "ISW" ) > 0; "Y"; "" ) -- -- Ready = Text field, Indexed -- -- Status = Text field, Indexed -- hopefully this makes sense. i would appreciate any feedback. thank you, jd. *Note: Some of the field names/values have been changed to simplify the query.
February 3, 200917 yr I believe you could speed things up considerably by turning Tenure, ISW and Points_c into STORED calculations. There are a few minor optimizations that could be applied to the calcs as well, but that's hardly the issue here. You mentioned a related file - but didn't elaborate on the relationship.
February 4, 200917 yr Author hi, the related file is a filenotes file, the relationship is based on the person id, so does not use any of the fields mentioned earlier... jd.
February 18, 200917 yr Author hi, we have changed all the calcs to be stored. however, we are still seeing the summary dialogue any thoughts? jd.
February 19, 200917 yr What dialogue? You didn't mention any dialogue before. And I still don't know what part the relationship plays here.
