February 27, 200917 yr I want to create a relational link to a field in a table hosted on an Oracle server. I have read-only ODBC access to the Oracle database so cannot make a calculated lower-case field at that end to connect to, but the key field I'm using is an email address with unpredictably mixed-case characters. The relational link only works if the case matches for both fields so I appear to be stuck. Any helpful suggestions would be much appreciated. Colin
February 27, 200917 yr Ouch. Still, I don't see that you have too many choices here. Try defining another relationship to the external table, using the x relational operator. This will enable you to retrieve a list of all the e-mail values in the table. Then you can get the correct version of your key value by: Let ( [ listOfValues = List ( AllRecords::eMail ) ; v = ValueCount ( Left ( listOfValues ; Position ( ¶ & listOfValues & ¶ ; ¶ & KeyValue & ¶ ; 1 ; 1 ) ) ) ] ; GetValue ( listOfValues ; v ) )
February 28, 200917 yr Actually, come to think of it: FilterValues ( List ( AllRecords::eMail ) ; KeyValue ) is both simpler and (in case the eMail values are not unique) will return a multi-key of all permutations of KeyValue occurring in the table.
