June 10, 200916 yr Hi! I have a layout that i'm trying to print on one page. It consist of a header, a "list" body with 6 records shown as a calendar, and a trailing grand summary with calculation fields in it. I can print the header and body, but can't get the trailing grand summary to print on the same page. Is there a way to capture the whole layout screen and print it on a single page?
June 11, 200916 yr you may need to reduce the size of elements on layout and make sure sliding is turned on so thing slide up. You can also go into page setup and reduce the output by a percentage.
