August 26, 200916 yr I am very new at this sorry if this is a dumb question. I need a script that find and replaces whatever it is i have on my clipboard meaning whatever it is i just copied. so i create a new script then go to perform find and replace....then specify...then on find what i want to put there a calculation i would guess that tells it to find whatever it is i have on my clip board. Is this even possible? all help is appreciated.
August 26, 200916 yr Filemaker provides no access to the clipboard other than copy and paste. And Find/Replace works only on fields, too. You could make your script paste into a global field, do Find/Replace and copy the result. Not sure why you need all this - perhaps there's a better way to accomplish what you're really after.
