How to filter a multi level relationship
I will try my best to explain this.
I have an external database in sql that I am pulling information from.
This is working exactly how I want it. Where I am running into issues is that I want to be able to filter the results returned by date (which is a variable in one of the tables)
Here is the issue.
In FMP i have a product table.
I have a relationship to an external table called "Items" and is linked by an item #.
Then the external "Items" table Occurence is linked to another external table Occurence called "CMS" by order number (which is in both of those tables, but not my FMP)
When I create a Portal for this with variables from both of these occurrences, all of the necessary variables are returned properly. Except that it returns information for all dates. I want to filter that down by date, so that I can create some summary fields.
I would like to be able to change the criteria between my FMP table, and the "Items" table to be if
Item = item (in the "Items" Occurence)
and
Order Date = Date Range I choose. (in the "CMS" Occurence)
But Order Date, is in the "CMS" table not in "Items".
How could I maintain my link to ITEMS, but only return variables that match the criteria in CMS?
Confusing... Sorry... I hope this makes sense.
Right now my relationship kind of looks like this:
Product Table(FMP) <-> Items (SQL) <-> CMS (SQL)
Any Ideas?
I am not sure how the ESS part plays in this. I presume you cannot add a global date field to the external Items table, but couldn't a calculation field = SomeFMPTable::gDate do the job?
Alternatively, you could link to another occurrence of CMS by date, and pull a list of order numbers to be used in filtering the relationship to Items.
The 2nd part of this.. which maybe you will have some insight...
If I want to create a summary field, and sub-summary parts of one of those external tables... how would I go about that?
I can't add the summary variables to those external occurrences....so I am not sure how to return all of the values, and then aggregate their values.
I prefer someone more experienced with ESS answer this. Perhaps you should create a new thread in the ESS section - it doesn't seem to be "the 2nd part of this".
