Serial Number will not auto generate in portal
Hi!
I have a portal on my layout and the first field in it is a auto generated serial number. For some reason whenever I create a new record, the portal does not fill in the serial number on my first portal line. But if I fill in the other boxes and go to the next portal row, the second serial number will fill in and so on.
Is there a trick to making the first row in the portal create this serial number?
Thank you so much in advance for any help!
Could you post a demo file showing the problem?
Was the data for the 1st record created before the serialization was added in define database?
Good luck,
James
http://www.soliantconsulting.com/blog/category/filemaker/
