December 22, 200916 yr I have set up a script to create a pdf copy of the current record, and email to a specified recipient. I added some comments as standard that will appear in the body of the email, such as: Code: Hi [recipients name::text field], Please find attached a pdf for you. "regards" [senders name::text field] "contact no :" [senders mobile no::text field] [logo::container field] However, all is well except for the logo field. It is always displayed as logo.gif, instead of the image itself. I tried setting the container field to global and not, with the same result. Is there a way to have the logo displayed as it should in the email body?
December 26, 200916 yr The built-in FM mail only sends plain email. For graphics or html, you'll need a plugin.
February 4, 201016 yr Author Ok, thanks Will not go down that path for now, but will remain with text only. Maybe fmp 11 will have that feature enabled.
