Sub-summary problem
Oooo-kay, here I go again!
I'm working on an expenses db currently.
For report purposes, I want it to look like this:
[Category]
[sub-category]
[individual entries]
(etc.)
[sub-category] total: [total by sub-c.]
[next Sub-category]
[next Sub-category] total: [total by sub-c.]
(and so forth... followed by:)
[Category] total: [total by Category]
(and then at the very bottom:)
Grand Total: [total of all items]
I'm attaching the db in question, so some smart person can take a look at it. The thing that's throwing me is that *sometimes* I get a Sub-category total, and sometimes I don't. This is more puzzling to me than if they didn't show up at all. I know the data's a little rough, there will be some editing to resolve category problems for indiv items. I don't think that should be affecting the way the subtotals are displaying...?
Any help would be gratefully appreciated!
expenses.fp7.zip
Your explanation was a bit weird. However, I downloaded the file and was able to modify it to what I thought you may have wanted to design. I based myself on the logic of what you wanted to report.
You can look at the file to see what I modified. Basically added a sub-summary part, and only used one summary field based on the Amount Total field you had specified.
The basic structure of your report would be this:
Category
Sub-Category
Items
Sub-Category
Category
Trailing Grand Summary
PS: You also made a mistake on a Sub-summary part. You specified it to sort by the Category field and you placed a Sub-category field on your layout. I think this is what was causing the behavior you mentioned.
expenses_modified.fp7.zip
Thank you, that's much closer to what I had in mind!
