using Mouse Wheel my layouts aren't changing??
My NAV buttons first/left/right/end buttons work fine
When using Mouse Wheel my layouts aren't changing??
Using the RecordRquest/Page Previous
GO layout1 or 2 etc
RecordRquest/Page Next
GO layout1 or 2 etc
RecordRquest/Page Last
GO layout1 or 2 etc
RecordRquest/Page First
GO layout1 or 2 etc
1. There is no script step "go to layout 1 or 2 etc". What is your actual script?
2. What is your question?
Ok i said etc.... yes the NAV script works well
click previous Nav button.. it goes to last rec, moves me to layout screen okay
if click nav button END.. or last my script works well again -- it goes to a layouts call it layoutEtc2
The question is when I use my mouse WHEEL my records scroll and my script does reacts.. so my layout is not set correctly... but my record advances correctly
I can always use 'hide Statusbar' thus causing my mouse wheel not to react... however the mouse wheel really nicely moves records viewing vs. Nav clicking
TIA
Try again. That's incomprehensible.
