Literature student needs help
Hi! I'm a french literature student trying to understand how to build a database... It's not exactly my cup of tea... so I need a little help:
I'm studying a literary magazine throughout time.
I have 3 tables: [color:blue]authors, [color:blue]articles and [color:blue]issues.
In [color:blue]Issues, there is a field listing the members of the [color:green]editorial committee at the time.
I'd like to have a field in my [color:blue]authors table showing the value of another [color:blue]issues field ([color:green]issue's number) for each record where the author's name is found inside the [color:green]editorial committee field.
For example: if, for the issue #3 of the magazine, the committee value was:
Paul Chamberland
Pierre Maheu
Anre Major
and, for the issue #4 it was
Pierre Maheu
Andre Major
Gerald Godin
I'd like to have a field in Pierre Maheu's record in the [color:blue]authors table showing that he has been in the committee for the 3rd and the 4th issue of the magazine.
But I cannot find how to do that!
...can you help me?
There are several ways to do this. For example, you could define a new relationship between Authors and (another occurrence of) Issues as:
Authors::Name = Issues 2::EditorialCommittee
Then a calculation in the Authors table (result is Text) =
List ( Issues 2::IssueNumber )
will return a list of the relevant issues. Note that this depends on the names matching exactly. It would be better to list the committee members in another table using a unique ID.
Thanks a lot! works like a charm!
You really helped me out!
