ASP & DSN less connection string
I would like to connect to myDB (FMP 10) from ASP without using DSN. The driver ODBC (DataDirect 32-BIT SequeLink 5.5) is installed.
How can I do this ? what connexion string do I have to use ?
Thank you
I tried this without success ...
Set myBD = Server.CreateObject("ADODB.Connection")
myBD.ConnectionString = "Provider=DataDirect 32-BIT SequeLink 5.5;SDSN=ASP_TEST;HST=localhost;PRT=2399;UID=Mano;PWD=123;"
If you have FMP11 you can create a DSN less connection.
