Help with a script
I'm trying to write a script that copies an ID number from one Layout/Table, goes to another Layout/Table and finds any records with the same ID that I copied. I'm trying the Perform Find and Set Variable script steps but can't get it right...
Many Thanks
Set $var to ID
Go to Layout Other
Enter Find Mode (no pause)
Set field to $var
Perform Find (no restore)
However, if you have a relationship btw the two tables using this field, then you can use the Go to Related Records script step.
I can't believe I forgot Enter Find Mode... Thanks so much!!
