August 4, 201015 yr I'm in the process of developing an Expense Report Database that is VERY similar to the preset Expense Report template of Filemaker 9... There are repeating fields that span a period of 1 week (7 days) for a total of 24 possible repetitions. I have everything set up fine and dandy... all of my calculations are working properly, the sum of fields, subtotals, totals, Rate per Km., etc... So here's the problem: There is a sudden need to include the receipt number (whether it be a series of numbers or letters) somewhere to validate the expense... but because these are calculation fields it adds the receipt numbers into the totals. Can anyone think of a way to resolve this issue without doing a drastic overhaul on my preexisting work? I have included the FM9 Expense Report that I am referring to... My calculations are virtually the same Expense_Report.zip
August 4, 201015 yr Author If it would be better to establish this via a Portal & a related database, I could do that too... but I don't think that'll make it any easier.
August 4, 201015 yr This handles part of it and may give you ideas. See yellow fields. Expense_Report_2.fp7.zip
August 4, 201015 yr Author I'm looking at the file now, It's perfect! Thank you so much. I truly appreciate the help!
